my set up! what you think?
Very very tiny cam for a 383 (218/224), stock stall, questionable heads, and low compression(why rebuild with the stock compression? They are already 10:4 from the factory!). You need more compression and a bigger cam for a 383...that is barely bigger then a stock cam.
I guess it is a start, and will pick up a LOT with a bigger cam and a stall converter, but for now it won't run any quicker then a stock shortblock with a good H/C package.
Build the motor with more compression, get a larger cam, get a stall and gears. You need to optimize your set up, not throw parts together. Definitely stop listening to whoever it is that you are getting your prior information/knowledge from.
Nitrous LOVES compression, LT1s are reverse cooled and are streetable with high compression, and most importantly IMO a cammed auto absolutely, positively NEEDS a stall to perform. It is not an option, a stock stalled auto will be a dog.
You can cut half a second off your time with the proper stall - no single mod besides nitrous comes close to that much bang for buck.
I'd go with a bigger cam. I'd get one custom made for your set up, and n2o usage plans.
Get some 3.73 gears as well.
