Tunercats education needed
Old Jun 11, 2009 | 10:40 PM
Grr's Avatar
Grr
Default Tunercats education needed
So i have the car running quite good on a 2-bar SD setup. It has a stumble/bog when hitting the throttle off idle. Is there an accel pump table in the $EE file anywhere? Anything i can do other than VE adjustments to correct it? My wideband took a **** yesterday, and i only get a decent reading on it from time to time. i would say its a lean stumble since it has gotten worse as i have gotten the car leaned out some, I started way rich. Also the car has a quite high idle on initial start for about 8-10 sec now , about 1400rpm, after leaning it out, what can i do specifically to get that back in line, overspeed timing at the high end mostly? When it was rich it would crank and go right to 675 with no surge at all.
Gary
