What to do know?
Old Jun 12, 2009 | 08:09 PM
96Formula6spd's Avatar
Default What to do know?
Well found all of my problems today. For the battery discharging looks like a loose battery cable. However for my ticking rockers the news is not so good. Looks like my oil pump has craped out of the driveshaft is not right. So anyways I have like maybe 5-10 pounds of oil pressure max. So I have few questions. The first one is do you have to remove the engine to change out the oil pump. I am pretty sure that you have to. The second question which I need to search for is to do with a lq4 or lq9 swap. I know you have to get the wiring harness and new k-member,steering shaft, and some other stuff. One question is can you keep the lt1 style t-56 or do you have to swap in a ls1 based one. I might end see if my dad is interested in my lt1/t-56 combo and ill get a lq4 or lq9/t56. Also can you cut and weld on new flanges to make a lt1 long tube header work on a lq engine? If this was your car what would you do?
opps the title should be now instead of know
