Back from the track - Advanced Induction 383
You need to follow standard NHRA guidelines. Every track has to abide by these rules. Take a look at the NHRA rule-book and it'll tell you everything you need to know.
That car has easy 10's in it. Just have some fun tweaking it, you'll get there. 3.90's are pushing it for a ~120mph trap unless you are running some bigger rear tires. My car is running a 25.7" tall tire and a loose converter and it is all done at 114-115mph, it just won't go any faster. I'd bet you will have the same problem.
What tires are you running?
My first outing was an 11.20@121. I kept picking at it, workin on it and got what I wanted.
I think I heard the converter lock up on the first pass (in person, not shown here) as the engine changed pitch at about the 1000' mark. I think that lockup switch is a must, Pants.
Take dyno vids!!!!!!!!!!!!!!!
we went to atco tonite and the DA was about +300ft he will be posting my shitty vid skills shortly....older camera, pixeled ugh.
im sure he'll scan the slip too
nice work AI!!! now he needs to get his *** on the dyno
-brandon
he trapped high 121/low 122
