How do I remove this?
Old Jun 16, 2009 | 09:24 PM
fuzzyjk's Avatar
Default How do I remove this?
There is two wires running in to a large hex nut in the oil pan, it is almost directly above the drain plug. It is the only wires left holding the wire harness/intake manifold from being removed.
thanx
Old Jun 16, 2009 | 09:30 PM
rkinney's Avatar
Just unplug it. The connector tab securing it to the sensor is recessed, just use a small pic or flat screw driver to release it.
Old Jun 17, 2009 | 09:50 AM
great421's Avatar
FYI -
That's your oil level sensor, an open circuit turns ON your Low Oil lamp; if you remove the sensor, connect the two wires to keep the I/P lamp OFF.
Old Jun 17, 2009 | 09:40 PM
fuzzyjk's Avatar
fantastic........ thanx
