Maf help!
Old Jun 16, 2009 | 10:28 PM
Hawk40's Avatar
Default Maf help!
i've made a couple of posts lately regarding my rough idle...after reading some people having problems with their MAF...i decided it def couldnt hurt to clean the connections...i sprayed the connector and the plug with WD40...now my car wont start!! i tried drying the connections out...no dice!
help!
Old Jun 16, 2009 | 10:29 PM
hitmanws6's Avatar
who told you to spray it with WD 40? you are only supposed to use MAF cleaner
Old Jun 16, 2009 | 10:31 PM
UFAIL's Avatar
try cleaning it with maf cleaner maybe you can save it
Old Jun 16, 2009 | 10:32 PM
Hawk40's Avatar
i didnt spray the actual maf or sensors...just the connection plug
Old Jun 16, 2009 | 10:37 PM
hitmanws6's Avatar
that could be your problem. the liquid could have destroyed the electronics in there. ive never heard of anyone cleaning the connections, just the actual MAF wires
Old Jun 16, 2009 | 10:42 PM
Hawk40's Avatar
i guess i'll sit and wait for it to dry out..maybe i'llt ry it again in the morning..anybody else got ideas? should wd40 have caused a problem?
Old Jun 16, 2009 | 10:45 PM
I8ASaleen's Avatar
Let it sit and dry out. Use QD electronic cleaner on the terminals and use some brake cleaner on the element (just don't touch it with anything!!!)
Old Jun 16, 2009 | 10:48 PM
fxgs's Avatar
Don't know if it will work with your year, but if your MAF is fried I have a almost brand new MAF off a '96 LT4 for $50 shipped............
Old Jun 16, 2009 | 10:55 PM
Hawk40's Avatar
thanks man...will carb cleaner work instead of brake? or is something special about brake cleaner
It might. I dont know if the ram air MAF is the same diameter as those used in the non-ram air.
btw...what did this maf come off of? as far as i know..the vette grand sport was the only '96 vehicle available with an LT4
Old Jun 16, 2009 | 10:56 PM
hitmanws6's Avatar
all 93 to 02 MAFs are the same
Old Jun 16, 2009 | 10:59 PM
I8ASaleen's Avatar
Carb cleaner is a little more caustic than brake cleaner isn't it? I used brake cleaner on mine b/c the electronics cleaner didn't cut the crap that was on the element. If you have brake cleaner I'd use it, but if not try the carb cleaner cautiously.
Old Jun 16, 2009 | 11:03 PM
Hawk40's Avatar
OR....i'll just play it safe and pick up some brake cleaner when i get the electronics cleaner tomorrow
Old Jun 16, 2009 | 11:05 PM
Hawk40's Avatar
besides whether or not the MAF is fried, shouldnt the car still start? it should be able to start without even having the maf plugged in...will run rough..but it should start
Old Jun 16, 2009 | 11:21 PM
Wicked94Z's Avatar
it should run just fine with the MAF unplugged
Old Jun 16, 2009 | 11:24 PM
I8ASaleen's Avatar
Yes, it will run w/o MAF - just don't throttle it any
