Gears!! Gears!! Gears!!
Old Jun 18, 2009 | 04:12 PM
nik1703's Avatar
Originally Posted by chavez885
This a 93 car i guess? I thought all the 6 speed cars were 3 series carriers after whatever year 93/94 the trans was changed.
He swapped the carrier i'm assuming
Johnny-LT1-runner's Avatar
Rockstar
Wow, all I can say is wow.
This may be the stupidest post I've read in a long, long time.
When you say, "popped da **** out of them",do you mean you broke them and had no choice, or you just felt like ******* your car up with the wrong gears?
Old Jun 18, 2009 | 04:58 PM
z_speedfreak's Avatar
LMAO this is one of the funniest tech posts I've seen in a long time..
Old Jun 18, 2009 | 05:07 PM
c4ls7's Avatar
get some 4.27's or 4.30's don't no which fits those housings but my dana 44 getting the 4.27 treatment
Old Jun 18, 2009 | 08:07 PM
Green3spd's Avatar
tell me if Im wrong but 93' cars had 3.23 final gears bc they had different trannys...?
Old Jun 18, 2009 | 08:32 PM
Purple95Z28's Avatar
Yeah, IIRC the 93's had 3.23 gears but a more aggressive 1st gear to help make up for that.
Old Jun 18, 2009 | 08:46 PM
Green3spd's Avatar
Ive read somewhere that a 93 6spd in 6th(stock gear) is like my 96 with 4.10s...?
Old Jun 18, 2009 | 09:20 PM
Anthony0908's Avatar
Hey BLOOD aint no thang but a chicken ****. You go back on da block slang some more ta get dem new gears ya heard. Blat Blat Blat keep it real One blood!
Old Jun 18, 2009 | 09:37 PM
monchis's Avatar
Red face I need a camaro master tech (lt4) please help!!
HEY GUYS I REALLY NEED SUM HELP, ONE OF MY HOSES CRAKED OPEN TODAY SO ALL MY ANTIFREEZE FELL OUT...MY CAR HEATED UP AND I PARKED IT RIGHT AWAY...I REPLACED THE HOSE FILLED IT WITH ANTIFREEZE CRANKED IT UP AND IT STILL KEPT HEATING UP... I CHEKED THE RADIATOR TO SEE IF IT WAS CLOGGED AND IT HAS WATER FLOW FROM ONE SIDE TO THE OTHER...THEN I REMOVED THE THERMOSTAT TO SEE IF THAT WAS THE PROBLEM AND IT STILL IT KEPT HEATING UP...THE RADIATOR IS FULL OF WATER AND ANTIFREEZE AND STILL IT HEATS UP RIGHT AWAY...THE ONLY THING THAT I CAN THINK OF NOW IS THE WATER PUMP NOT WORKIN BUT I DONT KNOW HOW THAT WOULD HAPPEN IF IT RUNS WITH THE CAMSHAFT??
IF YOU GUYS HAVE ANY SUGGESTIONS I WOULD REALLY APPRECIATE U ALL'S OPINION THANKS ALOT...
Old Jun 18, 2009 | 09:43 PM
chavez885's Avatar
oh god...here we go
Old Jun 18, 2009 | 09:48 PM
monchis's Avatar
Well so much for gettin sum advise!! I popped the gears meaning that they broke you ignorant person, and yes i did replace it with 2:73 meanwhile
i'll get my **** straight in about 2 weeks ready to run again and there were no series carrier change if you woul know enough you would kno that there is a number in the glove compartment that lets you kno what series u got!! U think i changed the stiker in there or what?? Lol you guys make me crak up with your ignorance...jajaja
Old Jun 18, 2009 | 09:49 PM
  #32
monchis's Avatar
Thanks for nuthing!!jaja
Old Jun 18, 2009 | 10:11 PM
  #33
moderate Z28's Avatar
Buncha punk *** ****** on here
Old Jun 18, 2009 | 10:27 PM
  #34
tbag_skywalker's Avatar
hey monchis, what the hell is 2:73??
Is that like the same thing as 2.73:1?
Old Jun 18, 2009 | 10:30 PM
  #35
Elliott's94Z's Avatar
^^ 2.73's are actually referred to as weak sauce
Old Jun 18, 2009 | 10:31 PM
  #36
Rockstar
Someone's pissy, hehehe. I haven't heard so many "jajajaja" since my brasilian friend was in town.
Maybe if you typed actual words (not ALL CAPS) you'd get some respect.
Ok, so you say heated up, how hot? What temp. did the gauge say?
And are you sure the whole engine is an LT4?
Old Jun 19, 2009 | 03:34 AM
  #37
monchis's Avatar
Forget it....
Old Jun 19, 2009 | 07:44 AM
  #38
the water pump can still fail even tho its cam drivin so def don't rule it out, try bleeding the system first tho, maybe its a big air bubble.
Old Jun 19, 2009 | 10:07 AM
  #39
marc97taws6's Avatar
The reality of how stupid some other people with f-bodies has dawned on me... Seriously, I thought the only people who did not know how to talk or spell and who always talk **** were Mustang guys.. This changes my perspective.
Old Jun 19, 2009 | 10:26 AM
  #40
Why dont you let the car cool down all the way.
Then add water till its filled. Let it run now you know the temp should be at or around 200 degrees.
Next bleed the air out the systmen.
Are your fans coming on? Fuse?
Last is water pump. Ight I cant wear skinny jeans cause my knot dont fit!
