AC Problems
Old Jun 19, 2009 | 08:01 PM
Hawk40's Avatar
Default AC Problems
tried to recharge my system and when i hook up....gauge says my pressure is really high (doesnt tell me psi..only that its "high")......i had this problem before and just kept messing with the connection and it finally went to the true reading and i was able to add refrigerant
anyone else have a similiar problem? help soon please..its 100 degrees here
Old Jun 20, 2009 | 11:40 AM
Hawk40's Avatar
ok so i drained all the refrigerant out..and refilled to the proper level...and its still blowing warm air...ideas?
Old Jun 20, 2009 | 11:50 AM
ClovisAutoMotion's Avatar
Those little fill gauge things they give you with the 134a cans never work right, unless you have a A/C manifold set its impossible to tell. How much did you put in after you evacuated the system? It should hold 2lbs or refridgerant. Also make sure the compressor is switching on when you try and fill it. If you evaucate the system but dont Vacuum it done a lot of times it'll have just enough pressure to keep the small cans from filling but not enough to close the pressure switch and allow the compressor to come on.
Side note: Was it not blowing cold before you tried to charge it? If so then you most likely have a leak somewhere. 9 times out of 10 if the ac isn;t blowing cold or at least cool the system is leaking.
