Catalytic converter!!
Unless you really need a cat, dont.
Otherwise a custom y with a cat is needed or a bullet type converter, but I am not sure if you can get one in without hitting the body.
I forgot to mention though. If you delete the cats, dont forget to get O2 Sims...Your car will run like CRAP if you dont. A/F Ratio will get all messed up and yeah, bad juju. You will need 2, and they are just a plug-n-play setup so it would take 30 seconds each to install. Then just tie the ends off somewhere with zip ties so they dont drag or burn, and your good to go.
I apologize if I seem un-educated but if I am wrong it is because I was misinformed by someone I thought I could trust on the issue lol. If I AM wrong, what will happen if you delete the CATS and leave the rear O2's? I dont wanna keep thinking the wrong thing
Thank you for clearing that up for me.
Back to the original topic and what I was getting at before using the info I just recieved lol...If you take out the cats either get O2 sims, or tune out the rear O2's to stop that SES light and code from popping up.
Thanks ss.slp.ls1
I still need a tune though... im pretty sure.
If you tune the code out, isn't it just supposed to be something that doesn't come up.
But I say you just leave it alone, and save up. Don't spend money twice.
