Rebuilding LT4 with 165k miles
I sincerly hope I am wrong about that though.
The LT4 crank will be nothing but a LT1 crank once you turn it undersized to repair the damage. Undercut and rolled fillets will but ground into when they turn the crank.
The LT4 rods are fractured cap, going to have a hard time finding oversized OD bearings to allow you to rebuild them.
$5K wont go as far as you think it will. I would budget $4K easy for a nice shortblock since you likely have to replace about everyting anyway.
NICE parts that are a good value, you can do it cheaper but it will be cheaper in EVERY sense of the word. Avoid the cast aftermarket cranks they are weaker than stock. If you use cheap chinese components Scat is better than Eagle.
Understand power is in the topend not the bottom, if you do just a shortblock and give it a bit more cam but bolt the heads back on untouched it wont make that much power.
I wouldn't be so quick to throw the block away. At least have it checked out to see if it is worth rebuilding. Agreed you can have a real nice short block for around 3 to 5K.
Are you looking for just out and out performance specific shops or are you looking into machine shops as well?
I got a spun main block for free and looked into repairing it, found some .020 over OD bearings that might do the trick combined with a new set of caps BUT they are not a performance bearing. So even the guy who found the bearing PN and would have been making the money off the line bore suggested I find another block.
For a local shop, go here to the Regional Forums, Southern Members, and ask the TN guys there.
I hope that helps and good luck on your rebuild
Dub
When In Doubt Do Without
If you're close by you could swing by with it, or me by you, and I'd take a look at it or help turn a wrench or two. I've got a decent sized garage with a couple of tools.
