Educate me on distributors
Second, my distributor is leaking oil, but is functioning fine from what I can tell. Are there repair/seal/gasket kits I can get?
If you are leaking oil from behind the opti, odds are your distributor seal is bad. At this point you might as well remove the timing cover and replace all of the seals. It would also be a good time to do a cam swap too.
Also is there any reason I shouldn't just buy this?
http://shop.oreillyauto.com/ProductD...pe=167&PTSet=A
In order to remove your timing cover you have to remove all of the oil pan bolt except for the last two. This will allow the front of the oil pan to lower the 1" it needs to free the timing cover. When you reinstall the timing cover, put a nice bead of RTV along where the oil pan seals to the timing cover.
http://dynaspark.net/
Would definately like to try this out.
