new motor idle
Old Jul 3, 2009 | 09:26 AM
97lt1z28's Avatar
Default new motor idle
The new motor i just put together runs really well. After i start it it idles around 850-900 and after it warms up the idle jumps to around 1450-1500 rpm. All the sensors are new with the rebuild. Any ideas? could this problem be from the tune thats in the computer or is it more likely to be a bad sensor?
Old Jul 3, 2009 | 10:04 AM
ZONES89RS's Avatar
In-Zane Moderator
Could be a poor tune.
Old Jul 3, 2009 | 10:50 AM
Smokinlt1's Avatar
could be vacuum leak.
Old Jul 3, 2009 | 07:12 PM
hitmanws6's Avatar
check the TB. mine did that because some rust built up in the spring not causing it to close all the way
Old Jul 4, 2009 | 12:15 PM
ss.slp.ls1's Avatar
As stated check for vacuum leaks.
Check your TPS voltage and IAC counts at idle with a scanner.
Old Jul 4, 2009 | 06:09 PM
97lt1z28's Avatar
thanks for the help......what do you guys suggest for at idle in park RPM and RPM in first gear?
