valve spring switching
Old Jul 3, 2009 | 12:22 PM
ls1f-body's Avatar
Default valve spring switching
will ls1 valve springs work on the lt1 engine?????
Old Jul 3, 2009 | 02:16 PM
speed_demon24's Avatar
They will with the same hardware 918's use.
Old Jul 4, 2009 | 12:12 PM
ss.slp.ls1's Avatar
One thing to note is that LS1 valves are lighter than LT1 valves.
Old Jul 5, 2009 | 01:57 AM
Wooshie's Avatar
stock springs are only good for stock cams and usually just barely. I wouldn't run anything bigger than a hotcam with 1:5 rockers on those springs SO as long as you want to change them use a good spring and run any cam you want.
BTW here are the ls1 cam specs.
`98-`00... 198/209 .500/.500 on a 119.5 LSA
`01-`04... 196/207 .467/.479 on a 116 LSA
