Multiple Problems
Old Jul 3, 2009 | 03:38 PM
transamws6_97's Avatar
Default Multiple Problems
Okay so recently I unbolted my dash and took out my radio and hvac and now the lights on my hvac panel wont work also for some reason my abs inop light wants to be on and so does the brake light for my e brake but sometimes it wont come on its either on or off when i start my car and also my low traction light will flicker with my brake light when im moving sometimes and its solid when im stopped but flashes when im moving i dont get it. Also my power steering keeps cutting out for a few seconds then will kick back in what would cause that? I replaced my power steering pump about 2 years ago.
Old Jul 4, 2009 | 09:52 AM
bump ttt
Old Jul 4, 2009 | 10:43 AM
SS RRR's Avatar
Village Troll
If the dash lights just started acting up when you took your dash it may be a good idea to take it back off and examine what happened. More than likely that is where the problem is originating.
As far as the steering goes, have you checked your fluid level? Check that, if full then you may need to bleed the power steering system. To do so is fairly easy- Put the front of the car on jackstands so the front wheels are suspended, start the engine, quickly turn the steering lock to lock. Do not keep the steering on lock. It's bad for the pump especially when low on fluid. Do this several times and then check your fluid. If it's low then simply refill and turn lock to lock several more times and keep checking.
Check to see if you have any leaks in the p/s system as well...
