Lt1 cam install?
Old Jul 9, 2009 | 01:54 AM
FiveOhhEatr's Avatar
Default Lt1 cam install?
Well my 94 t/a has about 130k on it. Is it stupid to put a cam in with this high of miles? whats a good cam to use with stock heads?
Old Jul 9, 2009 | 02:05 AM
ss.slp.ls1's Avatar
That depends. If you do a compression and leak down test and all checks out, then knock yourself out with the cam swap.
The CC503 hands down. That's the cam I have with stock heads. Works great. Let me know if you have any questions. I can tell you everything you need to know about swapping that cam in.
Old Jul 9, 2009 | 02:16 AM
do i need a tune after the install?
Old Jul 9, 2009 | 10:28 AM
ThreeHonks's Avatar
With that smaller cc503 cam it wont be totally necessary unless you jump up to bigger injectors. You can get a mail order tune for around $150 so why not
Old Jul 9, 2009 | 11:39 AM
ss.slp.ls1's Avatar
You will need a tune.
I got a mail order tune from MadTuner.
Old Jul 9, 2009 | 11:50 AM
xxRONNIExx's Avatar
Can we just pop the cam (cc503) in or would you need to also put install new rocker arms, pushrods, springs, etc?
Old Jul 9, 2009 | 12:07 PM
ss.slp.ls1's Avatar
No, you would shatter your springs and drop valves and all sorts of carnage would happen.
At the very least you NEED better springs and hardened pushrods. You can use your stock rockers if you want, but if you are going this far don't skimp. The follow is what you WANT:
Comp Cams "CC503" Grind# 276HR-12 part# 07-503-8 $250
Comp Cams beehive springs part# 26918-16 $174
Comp Cams retainters part# 787-16 $50
Comp Cams valve locks part# 648-16 $23
Comp Cams Pro Mag 7/16" 1.6 rr's part# 1305-16 $290
ARP 7/16" rocker arm studs part# 134-7103 $38
TrickFlow guideplates part# 30400623-8 $16
TrickFlow 7.2" chromemoly pushrods part# 21407200 $87
Felpro replacement valve seals part# SS72861 $19
You can get all of the above from SummitRacing
Old Jul 9, 2009 | 12:10 PM
xxRONNIExx's Avatar
Talking
Thanks for the information..youve answered like every question Ive had on this forum since Ive been here
Old Jul 9, 2009 | 12:18 PM
ss.slp.ls1's Avatar
LOL, no problem.
Don't forget that you will need a new timing cover gasket kit. I use the felpro kit that you can get at Autozone. Part# TCS45956 $14.
A new timing set is also recommended (order these from GMPartsDirect):
crank sprocket part# 10128346 $28
cam sprocket part# 10206039 '95-'97 part# 10128349 '93-'94 $35
chain pat# 10128485 $31
Old May 23, 2017 | 07:44 PM
Joseph Bland's Avatar
if i put the cc503 cam in my lt1 would i have to have it tuned
Old May 23, 2017 | 09:47 PM
BALLSS's Avatar
yes...
and you would need new valve springs. I would stay away from the Comp 915 or 918 bee hive.
Crane 10308-1 spring kit would be a drop in replacement and work very well with the 503 cam
