header studs for my lt1?
Mr. Gasket is the only company I have found that also makes a reduced header stud setup. It is 3/8" going into the head and 1/4" on the header side with locking nuts. Now they rate these as a 'race only' item, and I believe that is because they are only black-oxided, thus they would tend to rust over time, and if the 1/4" portion were to snap off I am not certain how successful you would be at trying to remove the rest of it in the head. If this isn't a daily driver, only sees good weather, never rain, and in general is treated like a race-only vehicle (like quite a few on here do), then you should be fine with them.
