pushrod length check how to?
Old Jul 12, 2009 | 03:09 PM
slownova73's Avatar
Default pushrod length check how to?
say i have a comp hi-tech length checker, what is the process i must go through to determine the correct length?
Old Jul 12, 2009 | 03:19 PM
RamAir95TA's Avatar
There are a few steps. First, you need to construct a solid lifter. Using one of the lifters you plan to use, disassemble it and remove the plunger. Insert a piece of metal (bolt, thread, doesn't matter what) and grind it to length so that the tip of the pushrod cup is up against the snap ring (i.e., mechanically pumping up the lifter, so that when the pushrod tool is loaded it won't depress the plunger, screwing up your readings). Reassemble the lifter and install it.
Here is a post courtesy of LE:
The following is a method of verifying proper valve train geometry. After you have estimated the required pushrod length using a Pushrod Length Checker, use this method to verify that the valve train geometry is correct (using the rockers you are using in your engine):
1
The first step is to install a solid lifter and an adjustable pushrod. Mark the tip of the valve with a marker
2
Install your rocker arm and set it up with zero lash.
3
Rotate the crankshaft clockwise several times. Remove the rocker arm. The contact pattern of the rocker tip will be where the marker has been wiped away from the valve tip. The pattern should be centered on the valve tip, and as narrow as possible. If it is not, experiment with varying the pushrod length to yield the best pattern.
4
Pushrod Too Long: Notice how the pattern is wide, and shifted to the exhaust side of the valve tip.
5
Pushrod Too Short: Notice how the pattern is wide, and shifted to the intake side of the valve tip.
6
Pushrod Length Correct: Notice how the pattern is narrow and is centered on the valve tip.
Old Jul 12, 2009 | 03:34 PM
slownova73's Avatar
mmhmmm, ok, thats kinda the idea i had but wasnt sure, thanks man, much appreciated
Old Jul 12, 2009 | 03:54 PM
Counted Out's Avatar
Posting so I don't lose this thread - I'll be doing this soon too.
