383 Feeler Thread
Old Jul 14, 2009 | 01:19 PM
JB_97ws6TA's Avatar
Default 383 Feeler Thread
Well I was going to do a budget 383 with a Scat rotating assembly but I was poking aorund and found a Callies Racemaster for a good price. The crank is rated for 1000 horse so I want to build the rest of the bottom pretty stout. I am thinking of just getting some forged SRP pistons but my question is rods. What are the best 6 inch rods H beam rods for the money?
Old Jul 14, 2009 | 01:57 PM
ss.slp.ls1's Avatar
I like Compstar rods.
Old Jul 14, 2009 | 02:03 PM
z28rob18's Avatar
i dont see a problem with eagle or scat. but compstar is good
Old Jul 14, 2009 | 11:40 PM
skinnies's Avatar
I had good luck with eagle h beam rods at ~900 crank hp, I'd look into a better piston though than the cheapo srp's!
Old Jul 14, 2009 | 11:50 PM
Wicked94Z's Avatar
manley rods here, oh i'd skip the shelf srp pistons. I've got some custom nitrous JEs, I'd be fine with some diamond or CP pistons though.
Old Jul 15, 2009 | 06:35 AM
z28rob18's Avatar
i have diamond pistons on eagle H beam rods
Old Jul 15, 2009 | 04:13 PM
ABA383's Avatar
I use JE pistons on Oliver billet steel 5.85" I beam rods on a forged Lunati crank in my 383...I've got 14 years 53,000 miles and cant tell you how many 1/4 mile passes...Zero issues...
--Alan
Old Jul 15, 2009 | 04:25 PM
JB_97ws6TA's Avatar
--Alan
That is exactly what I am looking for...a trouble free 383, I think I am going with manley 6 in rods and JE pistons, the longevity is in the machine work though so hopefully my machinist is up to standard as well
Old Jul 15, 2009 | 04:50 PM
Cruzer23's Avatar
Dont know how great this is, but its got forged everything and JE pistons, its only $2100
http://www.speedomotive.com/pc-512-7...roker-kit.aspx
Old Jul 15, 2009 | 04:55 PM
ss.slp.ls1's Avatar
That link doesn't list the band of crank or rods used...
This one does:
http://www.advancedinduction.com/AiP...sCompStar.html
Ai Forged 383cid LT1 Rotating Assembly Package:
Compstar Forged 4340 3.75" Stroke Crankshaft
Compstar Forged 4340 H-Beam Rods
Mahle Forged Pistons (-5cc, -16cc, or -26cc)
Mahle Plasma-Moly 1.5/1.5/3mm Ring Package
Mahle Steel Pins & Wire Locks
Main and Rod Bearings Included
Internally Pre-Balanced by Callies/CompStar!
$2196 - Ready for Assembly by your local machinist.
Old Jul 15, 2009 | 04:56 PM
JB_97ws6TA's Avatar
It would have been a great idea had I not already purchased a crank so now I am trying to match parts but now I am torn between two sets of pistons
http://www.summitracing.com/parts/MLE-SBC125030F05/
http://www.summitracing.com/parts/JEP-181911-8/
Old Jul 15, 2009 | 04:59 PM
ss.slp.ls1's Avatar
I like the JE pistons.
Old Jul 15, 2009 | 09:01 PM
racer7088's Avatar
The Compstar rods are a little better at clearing the cam and the block especially. They have about .050 more clearance at the outer bolt to block than the Eagles and maybe .080-.100 more than the Scat H-Beams which are the worst for clearance and will hit the cam as well at the shoulder.
I like the Eagles for the money and the Compstars if you can spend a little more.
Old Jul 16, 2009 | 04:48 PM
99blancoSS's Avatar
Heres our 383 rotating assembly:
Scat 4340 LTx 3.750 Crankshaft
Scat 4340 SBC ICR I-Beam 5.700 with 7/16ths Bolts
Wiseco PT025H3 5.5cc Pistons 4.030 Bore
1/16,1/16,3/16 Rings 1.425 Comp. Height (comes
with Ductile Iron Top Plasma Moly Rings)
ACL MS909 H Main Bearings for 350 SBC
ACL CB 663 H Rod Bearings for 2.100 SBC
Chamfered Race Bearings
balanced and shipped for $1775 (lower 48)
We can upgrade to Callies for $250.
