Crank hub bolt question ???
Old Jul 20, 2009 | 07:47 AM
monster81's Avatar
Default Crank hub bolt question ???
is there any diffrence between the Gen.I and Gen.II crank hub bolt. im swapping my crank hub and dumper from my old engine to my new build so i thought it would be better to replace the bolt and washer,,, i found this from ARP
http://www.summitracing.com/parts/AR...n/?prefilter=1
will this fit my stock crank
Old Jul 20, 2009 | 11:15 AM
ss.slp.ls1's Avatar
It's the right thread pitch, but I cant tell if the washer is too large or not or if the bolt is the right length.
Old Jul 20, 2009 | 02:26 PM
RamAir95TA's Avatar
It depends on what crank hub you have. Stock hubs need a small washer (more like a collar) while aftermarket hubs/dampers (i.e. ATI) require the large washer.
