Shorty's Vs. Longtubes
There are also shorties, mid-lengths, longtubes (non-equal), longtubes-equal length and stepped longtubes available for our cars... ALL have gains over stock manifolds.
Shorties - BBK, Pacesetter, Hooker - all 1-5/8" primaries - still good gains over stock manifolds - good for stock blocks+bolt-ons - not applicable to 383s, boosted, nitrous or other apps...
Mid-Lengths - Mac, AS&M - some are 1-5/8" (Mac), while some are 1-3/4" (AS&M) primaries - excellent gains over manifolds - 1-5/8" works well with stock displacement built cars (355) - 1-3/4" most gains seen with 383ci, boosted, nitrous apps... (side-note, more power is made with 1-3/4" mid-lengths on boosted apps over most longtubes)
Longtubes - Jet-Hot, Hooker, FLP/Dynatech, Kooks, Pacesetter, etc - most are 1-3/4" (I do believe you can order hookers in thier race version with 1-7/8" primaries) - Only Dynatech has velocity collectors available - some are available with specific y-pipes, most without cats (offroad) - FLPs have a velocity merge on the Y and came with both offroad pipes as well as cats - Believe only the hooker race 1-7/8" are equal-length, rest are unequal length (someone can chime in if this is inaccurate)... Only the 1-7/8" will have an advantage over 1-3/4" midlengths for boosted apps, and works excellent for heavy nitrous use as well...
Stepped Longtubes - Not sure of make - stepped from 1-7/8" to 1-3/4" primaries - Best design for nitrous applications - Also has an advantage over 1-3/4" midlengths in boosted apps...
Biggest advantage longtubes have is the ability to scavange exhaust gases, thus increasing efficiency within certain rpm ranges... Biggest disadvantage of shorties over midlengths or longtubes is stubbed/short collectors... Midlengths are better, but longtubes have proper sized/length collectors if designed properly...
There is a ground clearence loss with ALL longtubes (as the chassis was never designed for an exhaust pipe under the drivers floorpan)... No clearence loss with shorties or mid-lengths...
Dual-cats in longtubes or some midlengths (AS&M) are higher-flowing than a big single cat on shorties/midlengths...
Is nobody making 1.75" shorties anymore? I know mine are and I thought AS&M was but those didn't sell that well because of the tubes everywhere. As I recall, they were worse than manifolds when changing plugs.
As far as long tubes, the only available back then was the Hooker's. They hung way too low, at the time, and weren't going to let me pass emissions. If I was to do it now, over a decade later, I'd pony up for some long tubes with cats. Might not pass a visual, but it would pass a tailpipe or treadmill emissions test.
On my own cars, on the supercharged 383 in the T/A it is AS&M mid-lengths with a cat-pipe. On the Z28 convertible it is FLP longtubes with both cat-pipes and cats (gotta love the v-flanges). On my other T/A it was Edelbrocks.
The plug access on most headers really comes down to having the right tools (in most cases a shorty spark plug socket)... The absoloute BEST plug access is the Mac headers. All plugs in/out from the top without issue. There are some that REALLY suck, those would by the SLPs and a couple others that are damn near impossible to get plug access to or the keep the plug wires from burning...
SLP mids for single cat cars were pretty nice headers back then. My parent's have them on both Comp TA's.
