Identify this Vacuum line
Old Jul 26, 2009 | 11:25 PM
Marc3.4V6's Avatar
Default Identify this Vacuum line
While deleting the ac box from the firewall, this brittle vacuum line broke, it's attached to a wire harness that goes behind or into the computer.
How can I fix it?
Old Jul 26, 2009 | 11:28 PM
the_merv's Avatar
Veteran: Air Force
That's the check valve for the HVAC Vent System.. they are all vacumm controlled. You will have to get a new one.
Post pics of your delete progress..or when you get it done..
Old Jul 26, 2009 | 11:32 PM
shbox's Avatar
Old Jul 26, 2009 | 11:36 PM
Marc3.4V6's Avatar
Damn, can't I just plug it since I'm not using A/C?
Here's an ok pic so far:
You can see it exposed at the moment on the left. I don't plan on pulling the dash on the other side and getting it alll out from there, too much work for right now and the car hasn't been on the road for far too long. I basically just bashed the **** out of it while the head was off to get it out of there.
The sheet metal I have isn't big enough for my own firewall cover, I'll just buy a $40 one and call it done.
Old Jul 27, 2009 | 07:51 AM
the_merv's Avatar
Veteran: Air Force
You can plug it, but your Vents won't work.
Look for a good size piece of aluminum at a scrap yard.. it'll be definately cheaper than $40. I got mine for like $5..
