Lunati Timing chain
Old Nov 19, 2003 | 01:09 AM
BizZzatch350's Avatar
Moderator
Default Lunati Timing chain
Part # LUN-93094, its 108 and its for the non vented optis. Any one use it or know any thing about it? I have a brand new complete GM opti on the car as is, I'd like to reuse it and I dont want to spend any more money going over to the vented opti stuff If I dont have to.
Old Nov 23, 2003 | 11:31 PM
*High-Noon*'s Avatar
I've been thinking about ordering one myself, but as far as lunati goes you can rest assure that its a good quality product!
Old Nov 24, 2003 | 05:40 PM
Moderator
Thats what I was thinking, the only other option is that Comp Chain for non vented and it costs a ton of money, would be cheaper to just go vented an a LT4 chain. That Lunati chain doesnt cost much at all, I would just hope its a little better than a stock timing chain. I dont think I'm going any thing to radical, just want a nice rough cammy idle
Old Nov 25, 2003 | 11:48 PM
mighty mex's Avatar
I would use a reg. old SBC double roller timing chain and install an elec. water pump. Just my .02
Old Dec 4, 2003 | 08:41 PM
Z28andWS6's Avatar
i was wanting to do the sbc double roller too but have the non-vented opti. so will the chain clear the timing cover that i have?
Old Dec 6, 2003 | 08:02 PM
mighty mex's Avatar
just got to do a lil bit of grinding on the insode of the cover
not much
Old Dec 6, 2003 | 10:50 PM
ChrisB's Avatar
You need to convert to the new style opti to use the double roller. The opti is driven differently with the older style (hence the length difference in cam dowel pins - which you will also need to swap).
Old Dec 7, 2003 | 12:32 PM
Z28andWS6's Avatar
ok, thanks. guess i will stick with what i have since i just bought a new opti also.
 Michael S. Palmer
Old Dec 12, 2003 | 08:08 PM
PoorMan's Avatar
I think a guy over at camaroz28.com just broke one. He didn't replace the gears with it though and the cam gear ate teeth.
Jeff D.
Old Dec 16, 2003 | 03:02 PM
Camaroholic's Avatar
If you do go double roller, be careful which one you get.
This is a CompCams unit, for a hydraulic roller motor.
http://www.akmcables.com/camgear.jpg
I could not find anything else wrong with the motor other than the cam gear. Everything else was fine. So my assumption is that the cam gear failed.
The Cloyes has a solid center section for the cam gear.
-Andrew
