Carbed LT1?
I have bought one out of a lower mileage 96 TA that had a small engine fire
and some of the electronics were damaged, like injector plugs, dist cover,
and the plugs of some sensors. My question is can this engine be converted into carb form? Does anyone make a kit to convert this engine into a carbed setup?? I would like to keep the injection, but I would need alot of parts to do so. Any info would help, thanks.
- 12367600 LT 1/LT 4 Front Cover Plug
- 24502592 LT 1 Intake Manifold
i assume any SBC (Gen. I) carburator and distributor would be applicable. Keep in mind that u will have to run a non PCM controlled transmission, since u will eliminate the PCM and wirring harness.
