Cruise control w/ th350
You have to have the Speedo Signal sent to the PCM. If you have one of them little parts that goes on the TH350 to convert the Speedo Signal into an electronic one then you will be good.
The cruise will turn on, but it won't set a speed cause it has no signal sent to it telling it what speed to stay at unless you get the PCM the Signal.
That is what I was unsure of. I didnt know what controlled the cruise. Didnt know if was an independent sensor or from the PCM. Happen to know where to get the sensor to convert the th350 to electric?
https://ls1tech.com/forums/automatic...eedo-work.html
Here is a kit..
http://www.transmissioncenter.org/GM...eter_Gears.htm
Look for Kit #350E, it's about 3/4 way down the page.
LOL, JK. Merv's links should help you out. Good luck.
