Out of ideas...looking for suggestions
The car will start fairly easy but will have a tough time idling for about the first 30 seconds or so. Then the idle will clean up and sit around 930. After about 3-5 minutes the idle will break up and the car will die if I don't keep the throttle open. Now during this time, the number 8 primary is getting exterely hot (300+ deg) while the other primaries are around 160 - 180 deg.
Nothing is showing in Datamaster. No SES, no codes. IAC counts are little high, long term trims are in range. I thought maybe the #8 injector was going bad, so I swapped #1 and #8 but that didn't change anything. #8 plug looks clean and oddly enough I pulled the #3 plug to compare and it looked completely black.
At this point I am thinking it's either a bad injector wire in the harness or a vacuum leak somewhere. Any help or suggestions would be great!
Thanks!
Kyle
Thats strange why the #8 primary would be 2x as hot as the rest of them though. Mabye try pulling the injectors and see if they all spray when the car is turning over, or when the ignition is cycled. What kind of injectors are they?
Sorry man, that sucks hopefully someone can chime in and help you more than I can
I'm going to get a noid light and test the injector drivers & harness.
But its just really strange that the primary would be so hot. Mabye your valves are messed up or something. Thats just strange, be sure to post up if you figure anything out
On a serious note. I still think it is an injector issue more than likely a short in the injector wire. Noid light should tell us that.
Reason I say that is my buddy was having problems with the center primarys of his headers glowing red when the car was just idling and his valves were off. After they were adjusted the problem went away. But his car was carbed. It could be an injector too, but its strange that it would get hotter if the injector wasn't working correctly
The noid light showed some interesting things. When the car was first started, the noid light was working fine. However, after the car warmed up a few minutes, the noid light quit blinking on almost every cylinder, #8 had no light whatsoever, but the car was running. Thinking the PCM injector drivers might be failing, we swapped PCMs and loaded my tune into the new PCM. Same problem. PCM also threw a DTC - 44 which is Left bank O2 sensor error (lean condition indicated). This is clearly visible on the AFR guage which is reading 16-16.5 at idle.
Everything is pointing to the Dynaspark. I guess it's possible I could have gotten a bad one. We're going to put a factory opti back on and see if the problem disappears. If so, I guess I'll be calling the Dynaspark guys for a replacement.
I've changed out the opti and PCM. I also changed the O2 sensors over the weekend thinking that would help the code 44. I guess a compression test is next.
#1 - 195
#3 - 200
#5 - 204
#7 - 186
#2 - 195
#4 - 204
#6 - 202
#8 - 194
This has to be something electrical. I just can't find it!
