SEL On. Pulled codes
Old Aug 11, 2009 | 03:55 PM
sdotlog's Avatar
Exclamation SEL On. Pulled codes
P0200A injector control circuit
P0506B idle system low-idle air control responding
P1171D fuel system lean during acceleration
P1222D injector control circuiy intermittent
I'm guessing my stock injectors are crapping out?
Old Aug 11, 2009 | 03:59 PM
ss.slp.ls1's Avatar
Check your injectors and all wiring to them. I think it's possible for it to be the PCM as well.
Old Aug 11, 2009 | 10:49 PM
sdotlog's Avatar
Alright. I'm going to throw in my 36lb bosch III I bought from fic and fire it up over the weekend as long as I get my tune update for them. I'm guessing these codes came up when my car suddenly died on my couple weeks ago, symptoms of running out of fuel.
Old Aug 12, 2009 | 10:39 PM
sdotlog's Avatar
ideas anyone? wiring to the injectors are fine. i cleared the codes couple days ago. and went off this morning. the injector control circuit this time only.
Old Aug 13, 2009 | 12:35 AM
ss.slp.ls1's Avatar
Try swapping PCM's with a known goog one.
How did you verify the wiring? You can't just look at them...
Old Aug 13, 2009 | 12:48 AM
sdotlog's Avatar
LOL... You got me. Well I'll have to find a good PCM around here. I'm tlsure there a write up where I can test the plugs. Something like a volt meter or so?hopefully I can figure this out by this weekend as I'm throwing on the 36lb injectors in and getting a tune update.
Old Aug 16, 2009 | 02:55 PM
sdotlog's Avatar
:\ one thing after another. any method on finding out how to check the wiring?
