Abs Inop
Old Nov 22, 2003 | 09:28 AM
OneMeanZ's Avatar
Default Abs Inop
Okay, this warning light is being gay...whenever I start the car it's normal, comes on for about 2 or 3 seconds then goes off. Sometimes it will come on later when I'm driving, then I'll shut off the car, start it back up again and the light goes off. I know the light has something to do with the Anti-Lock Brakes, but can someone tell me what it really means and why it only comes on sometimes?
Old Dec 2, 2003 | 07:35 PM
Scott96LT1's Avatar
The ABS INOP light is just a dummy light (obviously). I had mine come on after a pass at the track once. Never happened again either and I had the ASR off at the time. I wouldnt really worry too much about it unless your ABS isnt working...
Maybe check the wiring?
Old Dec 3, 2003 | 12:57 PM
Gangly's Avatar
I would be halfway down the track and my ABS INOP light and Low Trac light would come on even though i wasnt spinning and my ABS worked perfectly fine when i tried to stop hard, never knew why.
Old Dec 3, 2003 | 01:13 PM
1LEThumper's Avatar
Is it a 3 channel (no TC) or 4 channel (traction control)?
Have you had the gears or diff changed? If so you might want to see if the reluctor ring on the diff (3 channel) has moved away from the sensor...this can cause an intermitent problem. Other than that, first thing I would do is check the wires to the speed sensors to make sure they are not cut or frayed.
Old Dec 8, 2003 | 12:31 PM
Silver98camss's Avatar
You may also want to have your brakes blead. The ABS system needs to be blead properly by a shop with the right tools. Had that problem on a 97 SS. The light would come on continuously, PITA too. Good luck
