I keep killing o2's
Old Aug 14, 2009 | 11:24 AM
phirepower's Avatar
Default I keep killing o2's
I have a full bolt ons, cam only lt1 formula 97 (obdII)
The cam is a GM 845 Specs are: 214/222 .520/.543 112
I am assuming that the reason I keep throwing o2 sensor codes (check engine) is because I am getting inadequate fuel.
Any idea if this is a good estimate, what else might I check?
I have noticed a slight drop in MPG, could an injector be stuck open?
Old Aug 14, 2009 | 12:06 PM
ss.slp.ls1's Avatar
So it's untuned?
Any exhaust leaks?
Running rich?
Old Aug 14, 2009 | 12:57 PM
phirepower's Avatar
The exhaust has no known leaks, I guess I could start off by tightening the header bolts again, they do have a habit of becoming unsprung
Old Aug 14, 2009 | 12:58 PM
phirepower's Avatar
Yes it is untuned for the time being
Old Aug 14, 2009 | 01:01 PM
strokin93z's Avatar
Try and fix simple things fix and then go with a tune and see what happens
