egr tube
Old Aug 16, 2009 | 04:16 PM
97badass's Avatar
Default egr tube
what can i use to block off the egr tube on the stock manifolds? i cant find a place to buy just the little tab to bolt on in its place. any ideas or suggestions to what you guys done?
Old Aug 16, 2009 | 09:01 PM
97badass's Avatar
slp you got an answer for me?
Old Aug 16, 2009 | 09:09 PM
RamAir95TA's Avatar
Remove the tube and gasket from the back of the intake manifold. Get some gasket material and some scrap metal, and cut out a piece of metal shaped like the gasket minus the center exhaust hole. Then sandwich the plate between two gaskets. It's easier to block off the tube from the intake manifold.
Old Aug 16, 2009 | 10:17 PM
vegasfbody's Avatar
got mine on ebay for like 5 bucks block off plates
