stall
Old Aug 18, 2009 | 05:42 PM
darrell hoagland's Avatar
Default stall
do yall think a 4200 would be to much for my set up?trannie has to come out so im gonna go bigger
Old Aug 18, 2009 | 05:46 PM
ss.slp.ls1's Avatar
No. Are you sticking with Yank?
Old Aug 18, 2009 | 05:49 PM
no gonna send mine off and get it restalled villigantie
Old Aug 18, 2009 | 05:57 PM
ss.slp.ls1's Avatar
Doh, I thought I read Yank. Vig is good. Restalled should be like new. Should be a good number considering your mods.
Old Aug 18, 2009 | 09:31 PM
RamAir95TA's Avatar
I have a 4000 and am very satisfied. I would consider going even bigger next time.
Old Aug 19, 2009 | 10:03 PM
stall will be sent off next week,and if i have the money gonna go direct port injection
Old Aug 19, 2009 | 10:16 PM
StealthFormula's Avatar
I would have said yes until I saw that your running a 150 shot of spray. You will first have to talk to them about it because the spray is going to kick the shift extension up and it could possibly make it too tight of a shift extension. BTW, I have a shift extension of 1000rpm with my 4000 stall so I couldn't even dream of spraying the car but theres alot of variables so just call them up and see what they say. Regardless I like my 4000 stall alot and would imagine a 4200 being real nice too.
Old Aug 19, 2009 | 10:28 PM
BADHAWK51's Avatar
I agree, I would not go any bigger than maybe a 3800 since you are spraying the car.
 Michael S. Palmer
Old Aug 19, 2009 | 10:42 PM
i wanna run goood on motor and whatever i can get out of the spray is a plus, the stall has antiballon plates in it
Old Aug 20, 2009 | 02:54 AM
robsquikz28's Avatar
id say a 4000 stall should be perfect with that setup
Old Aug 20, 2009 | 12:56 PM
I'm not a stall expert but I'm pretty sure anti balloon plates have nothing to do with shift extension. I believe they prevent it from flexing because the increased pressure of the fluids inside. For an N/A car something in the 1000rpm range for shift extension is money. With nitrous you do not want that, you want a lower extension like say 1500 or something along those lines because when you spray that 1000rpm extension will be even tighter which I think would wreak some havoc. Like I said I'm no expert but that's what I've heard and read.
Ask Vigilante though, I guarantee you that they steer you away from a 4200 stall. They are underrated anyways so thats more like a 4400-4500. When I was going to spray my car Yank wanted me to run the SS3600, they said the SS4000 would be too much but would be great N/A. I decided to stay N/A hence I switched to the PT4000.
Old Aug 20, 2009 | 04:04 PM
ok thanks
