Broken Valve spring= high map?
Old Aug 24, 2009 | 12:19 PM
94zgreenmachine's Avatar
Default Broken Valve spring= high map?
Can a broken valve spring cause a map reading, at idle, to read as if it were at WOT?
I already know of the problems/damage a broken valve spring can cause, I am working thru that. The valve never dropped, the keepers were still in it.
I had a reading of almost 90KPA @ idle. The broken valve spring wasn't heard till Datamaster was hooked up and showed high MAP DTC 33 and spark retard(3* to 4*). Most likely the valve hitting the piston......At that point we got a little closer to the engine.
Old Aug 25, 2009 | 03:15 AM
skinnies's Avatar
When I had a 918 break on me, my brakes went to junk(ie high map/low vacuum). It didn't hurt the valve or anything, just barely kissed the piston.
Old Aug 25, 2009 | 05:05 AM
I've done a leak-down test. I quit the test after I got it to about 5% leak. Anything above 15% should be considered for tear down and inspection. I spun the valve along the seat, by hand, and could feel nothing. It spun smooth so I am throwing the new spring on and am going to hold my breath. It broke at about 1500rpms.
Old Aug 25, 2009 | 05:36 AM
ADM's Avatar
ADM
What springs are you running?
Old Aug 25, 2009 | 09:35 AM
Pac 1220 Big block Bee-hive spring. About 175lbs on the seat, 375 on the nose. It wasn't coil bind. Looks like a defect in the spring. It peeled back and broke.
I'll post a pic tonight, works internet filter is horrible......
Old Aug 25, 2009 | 03:27 PM
Here is the pic:
Old Aug 25, 2009 | 04:00 PM
ss.slp.ls1's Avatar
I would hope you didn't get any metal shards anywhere inside the engine.
Old Aug 25, 2009 | 04:25 PM
The spring looks to be complete when the 3 pcs are put together...
Old Aug 26, 2009 | 05:30 PM
Yes, A broken spring can cause a high Map reading. I replaced #3 intake and it is all better now. I can even get the car to idle, imagine that
Hope this will help someone down the road....
