haveing lt-1 problems
Old Aug 26, 2009 | 08:34 PM
ohhyea93z28's Avatar
Default haveing lt-1 problems
ok this is what is going on. i just bought the car and it is boging all the time. the mods it has is coil packs, cai, and some kind of exhaust not sure what kind. it has a aftermarket alarm and i think they bypassed the vats but not sure the light it is. what i have done to try and fix the problem.
TPS- helped a little but same boging.
spark plugs and wires- again help by same thing.
fuel filter- same thing
iacv- idling is good it seem so idle really low though.
Plz help would love to get this car going good.
Old Aug 26, 2009 | 08:39 PM
Hawk40's Avatar
check --- fuel pressure, injectors, fuel reg valve, vacuum, and if u have a scanner...o2's
Old Aug 26, 2009 | 08:45 PM
Default lt1 problems
ive checked the fuel pressure and for vacuum leaks. would the 02 senors cause it. i heard that the vats might cause this what do you think? on the cai it does not have a map would that be a problem?
Old Aug 26, 2009 | 10:28 PM
Black96transam's Avatar
mine was doin that and it was the cat stoping up. cut off the cat and run perfect.. but yours might not be the same problem
