SJM Relocation Bracket
Old Aug 27, 2009 | 06:38 PM
86formula's Avatar
Default SJM Relocation Bracket
so i just went to put it on and either they sent me the wrong belt or im not putting the bracket on correctly, stock Alt, Stock Crank Pulley. the slot for adjustment goes down right? because if thats the case then i had to pry the alt over with the bolt to get the belt on, theres no give in the belt at all. can someone post up a pic for me because i cant find one
Old Aug 28, 2009 | 06:23 AM
86formula's Avatar
anyone??
Old Aug 29, 2009 | 01:13 AM
86formula's Avatar
how about a correct belt size? hoping to get this to work this weekend
Old Aug 29, 2009 | 05:55 AM
monster81's Avatar
yes the slot goes down, u should feel the tension on the belt by prying the alt. half way down the slot...so as u said ,u must be having the wrong belt size...u can wrap a wire or a rope around the pullys where the belt goes and find out the right belt size
Old Aug 29, 2009 | 09:26 AM
86formula's Avatar
that was what I figured, thanks for the info
