couple head questions
also wat injectors would you recomend for this set up?
Raising compression isn't just a function of milling the heads. You can also use a thinner head gasket. Milled heads and a .028 gasket would probably get you around 11.8:1 static, but that's a ballpark guesstimate.
30# injectors should be fine on your relatively mild setup.
thanks for your help
