LT1 builders enter here
Old Sep 5, 2009 | 03:47 PM
cat back 21's Avatar
Default LT1 builders enter here
Getting started on finishing my heads and cam install on my 94 LT1 A4 Camaro and have some questions .
1. What Cloyes double roller T/C part # fits a 94 LT1 ? I've seen different #s
2. Is there any modifying needed for a double roller t/c ?
3. What oil pump should I use ?
These are the first parts I need to buy to get the bottom half buttoned up before I install the heads . By the way I have the engine on a engine stand . The engine is a stock bottom end with LE1 heads and cam with 80k miles on the engine . Thanks in advance .
Old Sep 5, 2009 | 04:23 PM
RamAir95TA's Avatar
1.) I used Cloyes #3146.
2.) Quite a bit actually. You need to use the longer 93-95 crank hub, an electric water pump (after deleting the water pump drive gear), convert to a vented optispark setup, and use a 95+ timing cover.
3.) For the oil pump for your setup on a stock bottom end, the stock one is plenty. You may want to change to the white spring to bump the pressure slightly though. If you insist on a new pump, I'd go with the Melling select 10554 standard volume/pressure.
Old Sep 5, 2009 | 07:41 PM
1.Ahh yes , I forgot to mention I already have an electric water pump , a MSD vented opti , and I do have the long 94 crank hub , Ive read some guys grind some meat off the timing cover to make them fit , If I get A 95+ timing cover do I still need to grind off material ?
2. where do you get the white spring ?
Old Sep 5, 2009 | 08:50 PM
n2ocamaro's Avatar
Yes, mine had to be clearanced some.
Old Sep 7, 2009 | 02:22 PM
RamAir95TA's Avatar
The GM part number for the white spring is 3848911.
I did have to grind some material off of the timing cover, but not much at all (more like sanded, not grinded). Most notably is where the water pump drive protrudes. The metal tabs (on the back side) need to come completely off where the seal used to be.
Old Sep 7, 2009 | 02:27 PM
408StrokerSS's Avatar
with my 95 cover I had to do alot of grinding for my Doug Hebert racing Double roller
Old Sep 7, 2009 | 05:42 PM
so I guess I can use my 94 cover and my 94 balancer hub right ?
I'm thinking of buying a high volume meiling oil pump from Autozone , I'm just wondering if I should replace the spring on it ? Or should I just re use my old oil pump and replace the spring ?
