Ram Air>Cold Air
Old Sep 9, 2009 | 10:59 AM
wrd1972's Avatar
Some say that 1KPA loss is equal to 1% power loss. Clearly there is some loss in the twisty intake chute.
Here is the thread with my testing and findings:
https://ls1tech.com/forums/lt1-lt4-m...-diagnose.html
Old Sep 9, 2009 | 11:28 AM
1995blacktattop's Avatar
cool. i love the ram air setup. Here's my obligatory picture whoring of my own engine bay. good luck to those who want one. they are pricey and rare. i saw one at the T/A nats that had no gasket and a broken corner and it sold for $100. the same guy had a nicer box at home and he sold it to the guy who bought the crappy one for $200 as well. I got really lucky on mine and got the box which only needed to have some dbl sided tape applied to a couple small parts of the gasket (primarily the front part) and a K&N filter, along with the MAF to TB bellow, all for $115 shipped. that bellow from GM is $160 alone
Old Sep 9, 2009 | 06:19 PM
AChotrod's Avatar
On a dyno it prob would only make a slight difference. With a sealed factory set up at say about 100 mph the ram starts to take effect. Wich in my case means the last 20mph in the 1/4, im actually getting Ram Air gains!!. Not to mention the straight path helps a ton and even on a hot day the filter feels cool to the touch after a nice run.
Old Sep 9, 2009 | 08:52 PM
wrd1972's Avatar
Kind of funny how GM went back to the elbow on the 2010 SS.
Old Sep 9, 2009 | 09:08 PM
shbox's Avatar
They probably know that ram air is more cosmetic than anything.
Old Sep 9, 2009 | 09:44 PM
AChotrod's Avatar
It will hit the aftermaket asap.
Old Sep 9, 2009 | 10:00 PM
Hawk40's Avatar
if nothing else, its easier to get off quickly....
Old Sep 9, 2009 | 11:22 PM
hitmanws6's Avatar
tell me about it, now i dont have to get under the car and take off all those bolts. now its just 4 ***** and its off
Old Sep 9, 2009 | 11:24 PM
hitmanws6's Avatar
i still think on LT1s it is the most effective setup. at least with the 5th gens they made the elbow have a direct path
Old Sep 9, 2009 | 11:51 PM
yeah i was gonna say something like that. on an LT1 ram air is a major improvement over the 90 degree intake. on an LS1 it probably isn't as noticeable, especially because the airbox doesn't seal to the hood like it does on the LT1.
Old Sep 10, 2009 | 12:34 AM
what bolts? i don't remember taking off a bunch of bolts to get my stock airbox off. it just came right out. i did have to break some attatchment clips to get my air silencer out. i just left the thing in the fender that the airbox used to attatch to and got one of those plates for the lower part. I think i actually mounted the headlight module sideways but oh well. it's held down with tape.
Old Sep 10, 2009 | 12:38 AM
  #32
hitmanws6's Avatar
to get access to a CAI filter, you had to take off the panel under tae car to get to the filter. thats 7 bolts, then you had to attach the neck of the filter which sucked because the fit was so tight. i like now that i can take off my airbox normally
Old Sep 10, 2009 | 11:39 AM
  #33
oh ok. i never had a CAI on my car, just a stock airbox w/ a K&N filter. i don't think i've ever taken off that access panel under the bumper. i once changed a turn signal bulb the hard way (sliding my hand into the tight space down there) because i didn't know the access panel existed, lol. I did pull down the middle section with the 3 clips to change the foglight bulbs but i have never removed one of the side panels
Old Sep 10, 2009 | 06:06 PM
  #34
nik1703's Avatar
I have the suncoast setup with the k&n filter. that thing hisses like no other. it can be heard over my full exhaust at idle. what gives? lol
Old Sep 10, 2009 | 07:14 PM
  #35
AChotrod's Avatar
Mine sounds like a jet engine sucking air. Its awesome!!!!!!!
Old Sep 13, 2009 | 05:37 PM
  #36
formula vincent's Avatar
Default make hole bigger?
did you modify the air opening on the underside of the trufiber hood to make
it fit the air box ? from what i see in the pics of the hood at the trufiber
site is a small air slot cut out behind the air nostrills.
Old Sep 13, 2009 | 09:15 PM
  #37
madball's Avatar
I've had a 96' flat hood M6 Trans Am. Sold it to buy a 96' M6 WS6 and it did have a nice "suck" sound through the hood (mostly heard it immediatley after I shut the car off). Now I have a true "ram air" car, aka "procharger". You hear that thing sucken air like a kirby vacuum cleaner.
I have the air box with a K&N for sale. PM me offers for it.
Old Sep 14, 2009 | 01:08 PM
  #38
hitmanws6's Avatar
no modification was done or needed for that matter
Old Dec 23, 2009 | 07:36 PM
  #39
ThoR294's Avatar
Mine is a ws6 so I have the awesomeness of OEM ram air... hitman why is your airbox all gutted without the little shades like 1995tas and mine? does that really "help"? :O
Old Dec 23, 2009 | 09:26 PM
  #40
hitmanws6's Avatar
no clue if it helps or not, all the fins are gone now. the previous owner did that to the airbox, i just finished it
