Is bypassing the coolant to the TB worth it?
Old Sep 12, 2009 | 08:20 PM
viscousTA's Avatar
Default Is bypassing the coolant to the TB worth it?
Is bypassing the the coolant line to the trottle body worth it? does it run that much better?
Old Sep 12, 2009 | 09:06 PM
Badazz 97 TA's Avatar
you wont notice really any difference. It does help by not having hot coolant flowing through the throttle body heating up the air passing through.
Old Sep 12, 2009 | 09:45 PM
kierstyn's Avatar
For $1 or 2 why wouldnt it be good to get hot coolant away from the tb? Like he said you wont feel it but it is a good mod!
Old Sep 12, 2009 | 10:06 PM
NemeSS's Avatar
hot water is circulated thru tb for those very cold winter mornings, to heat up the incoming air some.
unless u live in some state where ur driving in freezing climate. u dont really need it.
Old Sep 12, 2009 | 10:15 PM
bore.me's Avatar
I just got a little kit for it on ebay. The seller showed a dyno chart with the bypass picking up 6hp. So 6hp for a few bucks is a good idea in my book. It's not going to change anything until the engine gets up to running temp. I'll probably keep the coolant running through it in the winter though.
Old Sep 12, 2009 | 10:59 PM
TRANSAM GT4's Avatar
Car Craft did an article on the LT1 free mods several years back. They showed a 5 h.p. difference with the mod. I changed mine but I couldn't tell a real difference.
Old Sep 12, 2009 | 11:12 PM
shbox's Avatar
It is to keep the TB from icing when driving in extreme cold for long periods. On a cold winter morning when you start your car, everything is the same temp (unless you have a block heater).
You don't need any parts to do a bypass on 95-97s.
Old Sep 12, 2009 | 11:56 PM
ninjai_ruken's Avatar
Yeah, you can buy a rubber cap kit from any hardware store or even Wal-Mart and do it yourself. I payed like 4$ for mine. I dont drive my Comp During the winter anyways. Thats what V6 Firebirds were made for, damn thing actually drives better in the snow then my V8...lol
Old Sep 13, 2009 | 01:24 AM
trx250r's Avatar
I have driven my car in single digits before with no problems after I bypassed the TB.
Old Sep 13, 2009 | 08:13 AM
Hot94Z28's Avatar
I have drove my car around here with it in the 20's and no problem.
Old Sep 13, 2009 | 12:19 PM
1badzee's Avatar
Coldest temperature my car has ever seen is 34*.. Damn South Florida..
