Header install help.
Old Sep 23, 2009 | 03:31 PM
noolah's Avatar
Default Header install help.
So I started to install my headers myself and i have run into a bit of a problem. I can not get the last bolt out of the manifold. I pb blasted the hell out of it and still nothing. Now the corners are rounded and i attempted to use a kit from sears for removing rounded bolts. That also has failed. I need help. I want to destroy my car right now out of frustration. I just want to get the headers on so i can drive it. Any suggestions would be greatly appreciated.
Old Sep 23, 2009 | 03:33 PM
Schweet97Z's Avatar
Anyway of heating it up? Torch or heat gun?
Old Sep 23, 2009 | 03:35 PM
noolah's Avatar
i have a heat gun but will that be hot enough?
Old Sep 23, 2009 | 03:38 PM
Schweet97Z's Avatar
I cant tell you that for sure, but it will definately make it warm. Worth a shot. Just hold it there on the bolt for awhile and becarefull not to burn yourself. Goodluck.
Old Sep 23, 2009 | 03:46 PM
djjab57's Avatar
do you need that hole, most headers on that back side use the other hole behind it
Old Sep 23, 2009 | 03:52 PM
nik1703's Avatar
Heat gun +1
or get one of those butate torches from home depot for 20 bucks
looks like this kinda, but bigger.
that should do the job.
Old Sep 23, 2009 | 04:18 PM
slow96z's Avatar
I agree on the torch idea. get a propane or butane torch, you should have one anyway. They come in really handy.
Old Sep 23, 2009 | 07:54 PM
old93camaro's Avatar
I say when all fail get a chizzle and knock the head off.....
Old Sep 23, 2009 | 10:27 PM
creepingdeath94's Avatar
Since it is already rounded, even a torch is going to be difficult to get any results as the head is rounded. Try and get a vise grip on there after you heat it pretty hot and try and pull/turn it. You can also try an "easy out" but that would probably require more room than you have...last but not least, yea, knock the head off and go from there.
Old Sep 23, 2009 | 11:45 PM
dirtynorth's Avatar
http://www.craftsman.com/shc/s/p_101...Mechanic+Tools
easy out and some heat these work awesome, great investment
