Dowel pin help
Old Sep 24, 2009 | 03:22 AM
RED PUNISHER Z's Avatar
Default Dowel pin help
i have a 1995 z28...i was takeing off my opti because it started misfiring and i noticed that the dowel pin was broken ... there is still a little peace there but i does not even come cloes to the opti to spin it ..what do i do to fix it..... i was thinking of welding a little peace of metal so i will spin the opti can some one give me some advice
Old Sep 24, 2009 | 06:16 AM
monster81's Avatar
is it a vented opti?
u dont need a long dowel pin for a non-vented opti, as long as the dowel pin gets throgh the cam sprocket, it should be fine,,,someone correct me if im wrong
Old Sep 24, 2009 | 06:37 AM
Badazz 97 TA's Avatar
'95 had vented optis. you are correct in your statement, but he will need the dowel pin
Old Sep 24, 2009 | 07:05 AM
shbox's Avatar
You are going to need to get that dowel pin out and replace it.
Old Sep 24, 2009 | 08:03 AM
the_merv's Avatar
How did it break is my question..
Old Sep 24, 2009 | 10:06 AM
Trick450r's Avatar
x2 not the biggest wear part on the car.
If it helps i used an old really heavy duty drill chuck to get the pin out of my cam.
Old Sep 24, 2009 | 09:05 PM
I dont know how it broke...i had the car for 7 months and have been driving the car like that ...it had a back fire and miss but that was it so i decided replace the opti becaus i had already relpaced the pulgs, wires and coil....when i took the opti off i saw the pin was broken it surprised me that the car was runing and the rotor was just lose in the cap the 2 screws had came off....yea its vented ...the guy i got it from told me its a lt4 hot cam i dont know if that makes a diff...but i tryed knocking it in so i can replace it but it does not move so know im drilling it out
Old Sep 24, 2009 | 09:09 PM
97Z28SS's Avatar
Perfect excuse to put a cam in it.
Old Sep 27, 2009 | 09:29 AM
97LT1's Avatar
x2 Jump in!
