idling sort of high.
Old Sep 24, 2009 | 03:52 PM
dc96ss383's Avatar
Default idling sort of high.
so my car starts up fine and everything seems to be ok only thing is my car idles at 1500 rmp. it should be at 1000 but its 500 above where its supposed to be. i ran it pretty hard the other day and when i downshifted then shifted back up; thats when it started idling higher. this is the second time it happens within a month span. the first time it seemed to have just been the throttle cable stuck. i checked it this time around and it doesnt seem to be that. anyone know what the problem could be? need help asap. thanks.
Old Sep 24, 2009 | 04:20 PM
Stroked96Bowtie's Avatar
There is a part on the side of the throttle body that regulates this, IAC motor. Reason I know is I had the same symptoms as you. I took it out, once it comes out you will see a spring attached to it. Just use some brake cleaner and clean it up, put it back together. Make sure the rubber o-ring seals are still good as it goes back together. I havent had a problem since.
Old Sep 24, 2009 | 04:26 PM
Greenbird97's Avatar
You might also check some of the vacuum hoses. There is one on the side of the throttle body near the top on mine that is kind of loose. Maybe you somehow knocked it off while driving spiritedly.
