need some help
Old Sep 27, 2009 | 03:15 PM
suprsick96's Avatar
Default need some help
well i just had a 355 built with srp piston , eagle 6inch rods , new eagle crank , and custom turbo cam ,put main studs and head studs in , um had the machine shop put the motor together heads and all . well summit sent the wrong head gaskets , and the machine shop still put the heads on and i have elderbrock head and it put a spot on the head where they put it on. well anyways i seen this sent the gaskets back ecive the right ones put them on and though it was done. well we got the motor in and started it up ran for about ten mins and nothing but white smoke , then two of the rocker studs broke . so then we check the plugs and each side of the motor there were brown spots and the plugs some looked good though . what should i do....?
Old Sep 27, 2009 | 03:28 PM
1NASTY'99SS's Avatar
**** salt!!! THATS BULL ****
