LT-1 Oil Priming - Engine Installed
Old Sep 29, 2009 | 10:53 AM
Jazz-LT1's Avatar
Arrow LT-1 Oil Priming - Engine Installed
I am just about finished with my LT1 rebuild installation. I installed the short block and the heads separately since I installed the engine from the topside. The intake is not yet installed on the car.
Now that the engine is in the car and nearly completely installed, I am a bit concerned about the amount of clearance for getting a drill and the GM priming tool (shaft) under the cowl of an 4th Gen F-body....
Anyone have any suggestions or is there plenty of clearance. I haven't actually tried to prime the car yet but thought I'd ask so I'm not surprised when I do.
Old Sep 29, 2009 | 10:59 AM
AChotrod's Avatar
Pull coil wire and injector fuse and let it crank untill the pressure comes up. If you did everything correct (like soaking the lifters, PRs) It should have full psi within a sec or 2.
No fuel and no spark = No probs.
Old Sep 29, 2009 | 11:09 AM
Jazz-LT1's Avatar
Everything has plenty of assembly lube, the lifters were soaked, etc., but the engine has also been sitting in the engine bay for a few weeks now since then. I did pack the oil pump with grease which should help it to prime. I'd much rather pre-oil / prime the engine if that's still possible.
Old Sep 29, 2009 | 11:19 AM
1redta's Avatar
hotrod is right just pull the coil wire and let it register on the oil presure gauger then let her rip
Old Sep 29, 2009 | 11:56 AM
SS RRR's Avatar
Village Troll
If you have plenty of oil and assy. lube on bearings/journals/valve tips/rockers you should have no problem with starting it. If you want to prime it then rent a right angle drill and set it to the highest speed. Depending on the speed of the drill and your clearances it may take several minutes for you to see traces of oil coming through the pushrods.
