ECM to PCM swap question
Old Oct 3, 2009 | 03:21 PM
ButchN's Avatar
Default ECM to PCM swap question
I have a 93 TA.
Would the underhood harness & PCM from a 96 TA be a "direct swap" so I can finally get a tune?
Would I need a MAF if it is a "direct swap"?
Anything else I should know?
Thanks
Old Oct 3, 2009 | 03:25 PM
shbox's Avatar
Yes, you will need a MAF and no, it won't be a direct swap. You'll have to do a little research on pinouts to make sure you get all the correct feeds going to the new harness.
Old Oct 3, 2009 | 05:21 PM
cgroh89's Avatar
You should go with a 94-95 pcm easier to tune from what I have heard.
When I swaped my 93 I needed
Pcm
Harness
MAF
Correct Iac Unit and Tb
Oil Pressure Sender
