What to expect?
Old Oct 4, 2009 | 08:13 PM
fuzzyjk's Avatar
Default What to expect?
1994 Z28, t-tops New crate LT1, new GM trans, Long tube headers, ORY, Crane 227, 1.6rr, LE1 heads, egr delete, 3600 stall and Powerdyne 6lbs Supercharger all on a stock rear. What do you feel the crank hp will be and a possible et?
Old Oct 4, 2009 | 08:37 PM
LSWHO's Avatar
I would guess mid 11s. If you dial it all in maybe LOW 11s.
Old Oct 4, 2009 | 08:48 PM
94Z28-MSTGKLR's Avatar
I bet you could see mid to low 11's depending on conditions and driver. Either way, its a nice setup and I personaly wouldn't even try to put the pedal down until you swap out that rear end for something else.
Old Oct 4, 2009 | 10:51 PM
fuzzyjk's Avatar
and oh ya....3.23 factory gears.
Am I looking at 500 crank hp?
I have all the parts, planning on starting the resto this week.
Old Oct 5, 2009 | 12:16 AM
jarretthise's Avatar
Maybe at the crank you will see 500 but def not at the rear wheels. And you def want it fine tuned. I am going with a much crazier setup and won't expect to see 500 rwhp even.
