93 lt1 questions
Old Oct 8, 2009 | 11:22 PM
93Firehawk's Avatar
Default 93 lt1 questions
I have a 93 firehawk and want to change out the high milage motor. Will any year lt1 work? I know they changed things in 94 and up. Can I make a newer engine work or do I have to change stuff?
Old Oct 8, 2009 | 11:35 PM
madmike9396's Avatar
Most things should just bolt right back up. Someone with more knowledge will chime in and hit u with the knowledge lol
Old Oct 9, 2009 | 07:52 AM
monster81's Avatar
any LT1 Long block will work just fine. but u will have to retain some of ur 93' engine external components, like the emmission stuff, fuel rail, wirring harness etc.
Old Oct 9, 2009 | 08:18 AM
jaysz2893's Avatar
the heads/block are the same (unless you get a LT1 out of a Vette or B-Body). The Intake is specific to 1993 as are the fuel rails. The Opti is on 93-94(optispark ver 1) is different than a 95 and up (Optispark II). You may need to change the cam gear and timing cover to re use a ver 1. If you use the 95+ block you will need to change the Harness for the opti too. They are different. I went with a MSD Opti for a 1993 on my car. Here is a good site with the LT1 differences broken down:
http://www.nookandtranny.com/Info_LT1.html
