How much more
Old Oct 9, 2009 | 10:13 PM
gregrob's Avatar
Default How much more
This winter I plan to add the following mods to what I have now.
EWP
52-54mm TB
Cutout
A/C Delete
Dyno Tune
150ish lbs weight reduction
New Rear shocks (stocks are SHOT)
SFC's (Spohn Chromoly)
LCA Relo's
Maybe a Torque Arm (Spohn chromoly)
New/Race Clutch (undecided)
Drag Wheels
What improvements in both ET and MPH
can be had?
Best 60' to date is a 1.91 and that was sadly dropping it at 3800 off the 2-step and immediately turning on the nitrous, spraying it out the hole.
It traps 100 on motor and 113 on spray. (Before you make fun of me remember the track is 5800ft and DA was 7500+ the day I ran last). Car is also currently MORE than full weight. (Stereo stuff, N20 kit, and I'm a fatass). And its untuned currently.
Thanks for any input
Old Oct 9, 2009 | 11:10 PM
kinglt-1's Avatar
I would say all that should put you bottom 12's at 116 on spray. Not bad for the da your workin with!!
Old Oct 9, 2009 | 11:16 PM
pyro719's Avatar
It will run high 11's with a 1.7 60 ft You still have gains in your nitrous tune as well. My 12.0 run was at 7800 da and all I have is this worthless hotcam lol!
