TH400 with 4.30 gears?
Old Oct 9, 2009 | 11:37 PM
86formula's Avatar
Default TH400 with 4.30 gears?
im preping for a future large turbo or nitrous build and going with a TH400 the first time around, the car has 4.30 gears in the 12bolt because its a 6spd currently on 27" tires. is this going to be a problem when i switch to the TH400? top speed in 3rd should be 121 not taking into account converter slip or the tires growing on the big end. once the motor is built i should be able to spin to 7k and a 27" tire should take me to 126 but again this isnt taking converter slip into play. ill be using a spragless Vig converter. anyone with some insight? i can always go to a 28 as well
Old Oct 10, 2009 | 04:34 AM
gregrob's Avatar
Id think a turbo would want a higher (numerically lower) gear, but thats just me. Its all gonna depend on the final setup.
toby's Avatar
for your current set up the 4.30 are fine. when you go to a turbo you will want to switch to a 3.42 or 3.55.
Old Oct 10, 2009 | 10:08 AM
86formula's Avatar
thats the kind of answer i was hoping for, with 27s i should go through at the peak of my power band
