Engine oil dipstick removal
couldnt have said it better good luck with the header install make sure you remove the coolant sensor on the driver side of the block so you dont break it coolant will poor out if it also
I am in the middle of an oil pump swap so I thought I might as well remove it while I am down there.
Expecting an O-ring seal to be there with the tube, does it usually tear during removal?
