Ready to get #s on the Dyno
Old Feb 13, 2010 | 12:00 AM
sdotlog's Avatar
File Type: bmp
Old Feb 13, 2010 | 10:50 AM
Ferg95 T/A's Avatar
Aren't those #'s a little low than what they should be? I am going to use that cam and I thought it should make atleast 370 rwhp. If not then I want a bigger cam
Old Feb 13, 2010 | 12:41 PM
Puck's Avatar
He is going through a decent sized stalled auto.
FWIW I only put down 350rwhp through a 3200 stall with a bigger cam but shitty heads and ran 11.7s. Dyno numbers don't mean dick .
Old Feb 13, 2010 | 12:44 PM
Ferg95 T/A's Avatar
Ok I will be going through a M6 so do you think that it would make that much?
Old Feb 13, 2010 | 03:53 PM
Puck's Avatar
With a similar combo an M6 will put down around 360rwhp. 370 is a bit optimistic with that baby emissions cam, but every car is different and the tune makes a huge difference so who knows.
Dialing in the combo as a whole is worth a LOT more then 10 peak rwhp anyway.
Old Feb 13, 2010 | 04:02 PM
BADMOON's Avatar
Originally Posted by sdotlog
Thanks. He's dyno tuning rates is cheaper than I initially thought. I'll be getting it done tomorrow afternoon though.
Honestly I think that is a reasonable price for an LT1 tune. Its a lot harder to tune an LT1 than an LS1. LT1 cars take a lot longer to get a spot on tune. Remember a dyno is only a tuning tool dont get that disappointed at the number take it to the track and look at the mph. My good buddy only makes 490 rwhp on a chasis dyno through a big stalled auto and with a 180 shot goin through a 9 inch rear. This is a stock bottom end LS1 car thats full weight, car will run 10.50's 10.60s all day long
Old Feb 13, 2010 | 04:15 PM
AChotrod's Avatar
Stock compression. gm alum le2 ported heads, ported le intake, tri y II headers with full 2.5" dual catback. stock maf.
That dyno doesnt look right at all. Could you please list all of your mods. Are you running cats, TB, WP, LTs? Are the rockers set correct? How old is the opti?
Also what are the corrected numbers. Those numbers arnt bad with an Emissions cam, and stalled auto but i do think the graph should be way smoother and have a few more ponies.
Old Feb 13, 2010 | 04:17 PM
AChotrod's Avatar
If my car made 490 plus a 180 shot and only went 10.5 id burn it.
Old Feb 13, 2010 | 04:31 PM
dlk1950's Avatar
I had a couple dips like that on my dyno,not as much,was told it was converter clutch slip.
Old Feb 13, 2010 | 04:38 PM
AChotrod's Avatar
Not only the dips but looks like somethings going on up top too. I guess it could be the stalled auto, and im used to looking at my smooth dyno's.
Old Feb 13, 2010 | 04:45 PM
ScreaminRedZ's Avatar
registered user
Also interested in the corrected numbers.
Old Feb 13, 2010 | 04:48 PM
  #32
dlk1950's Avatar
I think he should have made more power,I made that with my set up.
Old Feb 13, 2010 | 05:04 PM
  #33
airfix's Avatar
My numbers are in my sig, pretty close to the same engine set up mine was through a M6 10 bolt.
Old Feb 13, 2010 | 08:15 PM
  #34
sdotlog's Avatar
Yea about the mods:
High flow cats
54mm stock ported TB
Mezeire HD EWP
Tri Y II's from clear image/ through dual 2.5" exhaust
Raiss Intake
36lb injectors/ racetronix 255lph
rockers are set properly
Opti is probably over a year and half old.
Borg Warner Coil from csk(only one available asap)
How do I go about getting corrected numbers? Through the speedshop? I myself am a bit disappointed. Maybe f body maf would help a bit. Cats and mufflers hampering the exhaust side? Had contact with Lloyd and saids it's reading a bit low as well.
Old Feb 13, 2010 | 08:52 PM
  #35
Elliott's94Z's Avatar
Well got it done and put down 342rwhp and 338rwtq iirc. That's with the largest emissions friendly cam that Lloyd had available. I'll get the graph posted whenn the speed shop emails it to me.
Nice bro now it's time to head my way and hit up the track with us!
Old Feb 13, 2010 | 10:52 PM
  #36
sdotlog's Avatar
Might just do it when it gets nicer.
Old Feb 13, 2010 | 11:41 PM
  #37
Puck's Avatar
Same here, the most noticable one was right at the same spot too.
+1 .
He is running cats which cost some hp and tri-Y headers which lower the rpm range and also cost hp compared to traditional longtubes...I think his numbers are right where they should be, and if he has the suspension it will ET a hell of a lot better then any 340rwhp M6 ever will.
Old Feb 19, 2010 | 11:09 PM
  #38
sdotlog's Avatar
What are the consequences of me running w/o cats? I'm thinking of going with a different header. I'm thinking of hitting another dyno and seeing what it does again. I'll get some track times and, if I'm still not happy. I guess I'll get a bigger cam, or even better another head/cam setup.
Old Feb 20, 2010 | 06:12 AM
  #39
96capricemgr's Avatar
Funny thing is bowtienut(Pat Gish) is running tri-ys on his stock shortblock car, putting down 425rwhp.
https://ls1tech.com/forums/lt1-lt4-m...4-425rwhp.html
I did not post this to say sdotlog should have made 425rwhp. I posted it to say the Tri-Ys can't be all that bad if they let another car make that kind of power.
Old Feb 20, 2010 | 09:48 AM
  #40
Puck's Avatar
I never said they were that bad either. I just said they lower the rpm range compared to full longtubes at the expense of some top end. Both FACTS.
The single scenario comparisons are useless - I cut high 1.5 60's on my stock 10 bolt and ran 11s, does that mean 10-bolts aren't all that bad and upgrading is a waste??? Sikora ran 8's on LT4 heads, does that mean aftermarket heads are useless to anyone slower then 8s??
Not sure what your post means, if anything. At least you didn't link to AI's site this time? .
To the OP: Glad you got it dyno tuned and running well - now take it to the track and have some fun!
