LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   What's with the LS7 lifters? (https://ls1tech.com/forums/lt1-lt4-modifications/1191629-whats-ls7-lifters.html)
samckitt Oct 14, 2009 08:18 AM
Why do I see so many posts of people who are using these lifters in an LT1? What is so special with them?
stevo9389 Oct 14, 2009 08:22 AM
they are supposed to be the factory replacement.
Elliott's94Z Oct 14, 2009 08:22 AM
The LS7 lifters are the stock replacements. If you go to a GM parts counter that is what they will sell you. Nothing really special about them. I'm running them and they work great.
Jazz-LT1 Oct 14, 2009 08:34 AM
They are a good lifter, probably as good as the aftermarket ones but at 1/3 of the price.
samckitt Oct 14, 2009 08:35 AM
Ah I see. Thought there was some performance advantage or something.
Elliott's94Z Oct 14, 2009 08:40 AM
I found the best price through GMPARTSDIRECT if you go with a set.
wrd1972 Oct 14, 2009 08:45 AM
They are direct replacements for the LT1 lifter. They are also much cheaper than the LT1 lifters. They are slightly more robust on the ends where the retaining clips go and that is all. The bores, pistons, disks, springs are the same in both lifters.
You may need a slighlty longer pushrod when using the LS7 lifters over the LT1 lifters to retain correct pushrod geometry. No performance advantage at all. Just more robust.
J2Pharren1 Oct 14, 2009 08:50 AM
I knew they were the stock replacement, but do they make a good choice when using an aftermarket cam?
Elliott's94Z Oct 14, 2009 08:55 AM
They work just fine with an aftermarket camshaft. Running them with my AI cam with no issues.
BTC Oct 14, 2009 09:29 AM
How much was shipping? Less than a grand? What's the part number for these lifters?
Elliott's94Z Oct 14, 2009 09:48 AM
I picked them up for $107.00 shipped from GMPARTSDIRECT a while ago.
LS7 #12499225
GMDIRECT has them for $114.40 at the moment.
the_merv Oct 14, 2009 10:04 AM
They are supposed to be suited for higher RPM's. :)
Elliott's94Z Oct 14, 2009 10:05 AM
True Story :nod:
BTC Oct 14, 2009 10:15 AM
LS7 #12499225
I've priced a lot of stuff at GMPartsDirect. Their prices always look great, and then they ask you to bend over so they can add their shipping charges. They have those lifters priced at 114.40 right now, with estimated shipping of 24.02, for a total of 138.42. It would be interesting to see what Jason Cromer would charge. I bet he would ship them for no more than five bucks. When all is said and done, he's always beaten GMPartDirect on everything I've ever bought from him.
Elliott's94Z Oct 14, 2009 10:33 AM
Either way get them coming! :)
wrd1972 Oct 14, 2009 11:06 AM
I dont like GMpartsdirect becuae you can not talk to them via phone. I dont want to do bussiness with any retailer that has no phone support. Shipping is a bit high IMHO too.
Sam Taylor is where I always go and the prices are great.
Bersaglieri Oct 14, 2009 11:37 AM
SDPC has alot of GM parts, as does Summit. I like buying from people who exist somewhere and I can call or drive when nothing shows up.
-Dustin-
gregrob Oct 14, 2009 12:38 PM
Do NOT order from gmpartsdirect whatever you do!
These lifters are nice, but everyone freaking out and frothing at the mouth over them is a little much
Stockers work FINE for most people.
My car had been maintained well and at 90k, the lifters showed zero signs of wear.
I asked Ron at AI about lifters and he said the factory GM part is hard to beat. If it looks good and seems to operate good, its probably good.
I say if your lifters pass a visual inspection and have been running fine, run them and waste money on something else. Especially considering the fact that these will also change pushrod geometry and require a different length pr if you want to correct it.
.02
Bersaglieri Oct 14, 2009 01:04 PM
Ran my stock lifters with the CC306 and they have over 100k on them. I'll be using the same ones on my larger LE cam.
-Dustin-
samckitt Oct 14, 2009 01:07 PM
I'm not in the market or have the need for new lifters. Just wondered what all the hype was with the LS7 lifters.
© 2026 MH Sub I, LLC dba Internet Brands
